Question: lift pump
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I've got TTS pumps.... I don't even know if they are running. I haven't since day one. I just noticed that I don't drop rail pressure nearly as bad haha.
Same as KDs on my 05 but they drop when you start adding big fuel
they have been on my truck for 4 years and run all the time
At best i think 500hp anything over you need to go bigger JMHO
My cheap carter would out fuel both KDs:( I know there is new ones that are suppose to be a lil better...But
I cant wait to try the fuel lab:D HINT HINT Dale
FMOS
Hard Up
Nov 19, 2008
352
Fort McMurray, Alberta, Canada
Hmm... Maybe I'll have to upgrade to something decent. I always wanted to put a fuel pres. gauge in line to check it out but I'm so lazy its unreal. Unless I'm getting paid to do it, I'm pretty much useless.
If I go to blackout I'm going to have to bring something atleast somewhat impressive with me... so I'll spend some time on the tuning over the next couple weeks and see what turns up when I put more fuel in. Right now I'm at a 2800-2900 pulse width and no drop in RP.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
It only hurts more when you see what the pressure does:D
paint94979
Beer Nazi
Sep 18, 2006
11,715
As in, she's going to blow when I up the pulsewidth? Or as in, I'm going to blow my wallet open buying dual fuelers to maintain rail pressure when I try and make some more power?
You don't need dual cp3's to hold 26,000psi :D
13,765
834
My TTS pumps hold 4 psi after the filter at WOT on my big tunes. Maybe I got lucky and got the good ones.
9,906
152
A FASS is louder than the ppe. It flows more as well and is not a flow through. They are expensive but well built pumps. My carter fuel transfer pump is even more noisy, but I wouldn't use it as a lift pump.
I just got a fuelab pump-interested in seeing how quiet it is-they are supposed to be just as quiet as a KD and the one I have supposedly flows 200gph at 20psi!
9,906
152
Fearing for my life when Kat entered the freeway!!:rofl:
;):hug:
