According to SI it is wired to the ECM. I searched all that out last night in the middle of the night. What I dont know is if the ECM actually triggers the pump. If it does, then the grey wire in F1 of the red connector will be hot as the fuel pump supply voltage. If theres no wire there then all I have to do is put a connector in there. I would ASSuME it is still in the programming, but then again.....
if you go back a couple post you will see what i found, see if you see that same thing. Im going to put a dmm in the prime terminal and see if I get anything. I cant imagine it working because why would kennedy design a $145 box if it was already in there, someone would have found this in the last 10 years.
