Ok I installed my new FASS 150 lift pump in the LLY and put in a sinister diesel sump kit at the same time. I followed the directions on both as well as a couple videos I watched. Everything went together nice and I let it sit over night with a full tank to ensure no leaks.
Started it up and it all sounded good, slight hum like a normal fuel pump up close but nothing I would cal loud. Drove it about 50 miles that day then it sat for two days. Went to start it up and it’s making a nasty grinding type sound which, from what I can read is a cavitation type sound. If I loosen the water filter screw while running the sound goes away then after awhile it will come back. All the lines are tight, I primed the fuel filter by loosening it, running it till gas came out then tightening up the filter, I even cracked the bleeder valve and completely covered myself and engine bay with gas haha. Still making this noise.
