What tires?Dustin at Diesel Addiction is installing a Cognito 5-7 inch lift, new 4 inch exhaust, cold air kit and tune. The Ultra Phantom 20 x 9 rims and 35x12,5R20 tires are on order. I haven't been this excited since I was a kid at Christmas.
I think I've almost installed every lift on several models, and sold thousands of Cognito. I personally have a Tuff Country 1pc sub frame 4" and a Cognito 4/6" on my trucks. I've beat the hell out of both. The TC has been on the truck since 08 with hundreds of 1/4mi passes, sled pulls and a few dyno runs, not forgetting all of the street fun. The Cognito has a bunch as well but is a newer kit. Comparing the two, the Cognito rides better, and has a more controlled ride than the TC. Turning radius is about the same. Parts quality and overall package Cognito wins hands down. Both are overall great product, and work well.
Russ... What cognito kit would work best to get just a little more lift the factory n b able to lower it down to have flat cv angles for racing and run a 35 inch tire while not at track?
Since we're on the topic. Anyone know if you can fit 37s on a 4-6 lift ? And at what kind of bs and offset.
4" kit would work perfect, that's what I've always used.
Depends who you talk too..., if you listen to the "I fit 37's on my stock height truck" crowd on another forum, you don't need a lift at all. If you want to be able to actually use the tire and suspension correctly, Cognito recommends a 7-9" package with 9-10" wheel and 4.5-5.0" back space. There are so many tire/wheel fitments that work, just depends what look you are after, and what you can deal with.
I was thinking a 20x10 wheel. 5" bs and 0 offset. With 37x13.5.
I can crank it a little higher still. Or add lift keys. I only need like an inch on the fender side to fit. Need to double check my current backspacing. I think it's 4 so the extra inch should help.
You will clear just fine with that setup, I have 4.5" bs and 0 offset. You will have rubbing issues with the stock front fender at full lock or flexing. Mine doesn't because of my fiberglass fender, just a little at full lock while flexing from the pinch weld part that I need to shave off.
Sorry for the derail. Post up pics when you get it done!Truck is currently in the shop getting a Cognito 7-9 lift, new exhaust, cold air intake and tune. Will be installing 35 inch tires on 20 inch rims this weekend.
I haven't been this excited since I was a kid at Christmas.:rofl::rofl:
