Im putting my 6" zone lift on my truck and everything has gone pretty smooth....that is until now.
I have the front and rear NEW differential drop down brackets installed..and it was kinda a bitch to get the front diff in. I had to jack on the diff quite a bit to get the back holes to line up. But thats in now, However when i went to put my LCA on (they have new bushings)...The LCAs where 1/2" TOO WIDE wtf. So i had to put a bottle jack between the two diff brackets to separate them enough, has anyone else encountered problems like this? I don't like that i had to jack on the diff to get it bolted in...nor do i like that I had to jack the brackets apart. Remind you all the bolts are loose.....so nothing should be this tight!!
Suggestions?? Im about to go back through everything today and see if I did something wrong even though everything is straight forward
