Most if not all the highest horsepower street driven diesels run Garretts
Real world examples?
Cant without machine work.
Magnus
Yes garrett has some nice stuff.but you have to special order a racing turbo.
The airworks are out of the box
Turbos.
from mobile
I run a Borg 75/87/.90 for daily driving but it chokes out at high rpm. I have a 1.25 housing that I swap out for the track.
I had an airworks engineer explain to me that the 87 tw is only down about 2% on flow from the 96.
Howevere the 96 will transfer more energy.
So with the 80 you may notice a lack of boost.
But with a 75mm is not going to require as much energy to turn.
The 1.0 housing will also be somewhat tight so the flow required to spin the 80 may be at higher drive pressure.
Why not start at the 1.25 housing that bw recomends since you are spaying the truck, or try just the 87 tw since the cam and heads are stock?
Without knowing your exact goal I may be missing something. Just kinda throwing it out there.
from mobile
