Well I think my stock Allison is getting a little tired. No codes or anything and it's still holding tunes fine but I've noticed the shifts aren't as nice as they used to be. So the past several months I've been going back and forth between a built trans or swapping in a zf6. My first Duramax was a zf and I kick myself for selling it every time I see the truck.
So that's the route I'm going. I'll be sourcing a trans locally hopefully. Probably do the swap here in a couple months. Plan is a dual disk of some kind. Possibly South-Bend but going to research valair and Kennys Pulling Parts.
Questions I haven't found answers to are: can the Allison bellhousing to engine bolts be reused with the zf?
Can the transfer case to trans bolts be reused as well?
How does the aluminum rear driveshaft hold up to abuse from a zf? (My old zf had a steel shaft, don't know if they ever came with aluminum from factory)
Best to stick with gm slave/master cylinders or have people had good luck with aftermarket?
Sorry for all the questions, I will likely do it at work so I don't want to tie up a lift any longer than necessary.
