leaking anti freeze
deer hunter
Feb 9, 2014
chevy 2002 Duramax diesel i was told gases in anti freeze but truck does not smoke and does not run hot could there be coolant leaking thru turbo I have been told possible head Gasket really dont want to hear that has any body had problems like this or simalar please help!!!;)
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Need more info like miles and add ons (HP) any work been performed etc etc . To answer your question most likely NO perhaps the small line has leaked attached to the turbo but you would visually see that.
If there is exhaust gases in your coolant then it most likely is a HG or perhaps a Injector Cup.
deer hunter
Feb 9, 2014
Had Injectors done in October also this truck has banks system put on in july does not run hot and never overheated but looks like I may be paying a bundle for repairs!:(
bluepittsrace
bow ties or nothing
Jan 8, 2014
circleville,ohio
I know where your coming from I had same post about 3-4 weeks ago I ran several test and spent close to 300 trying to convince myself it wasn't between coolant stats and test kits so before you go buying a lot or changing stuff with hopes do a couple checks if getting gasses in your coolant 1- is top hose staying hard. 2 - can you see air bubbles coming into resv.tank 3- is it puking coolant out overflow if yes to those looks like head gaskets I went one step further to confirm and bought coolant exhaust gas test first couple times wouldn't read had small leak but had boy hold it at about 1500 rpm while I checked two more time and they was positive just got kit installed with studs from creatures next day 930.00 message me if got any questions I was in denial for couple weeks since truck ran as always had no change I know I'll probably here about this being long but hope it helps pm me if any other help needed
deer hunter
Feb 9, 2014
Did your truck blow white smoke and did it clear also did coolant light come on after about 30 miles or so what is crazy I never over heated and it blows no smoke while driving this sucks truck has 184000 miles on runs strong I pull a 34.5 toy hauler I thank you for the Info!!:confused:
