leak test time :(
joe@HSPDIESEL
Jun 25, 2013
220
Like I said I would like to go to a full bridge as I want to buildup around it not have to buy one later, I had a nrand new profab egr delete pipe I sold bc I want to do everything now
We can definitely take care of you! You have a few options with the LLY. We have a factory style bridge that would work with a 3" cold side tube as well as the 3" Bridge/tube we use in our twin kits.
Factory Setup
3" Bridge
Complete Setup - Twin Style
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,541
526
Central OH
You only need to use regulated air supply and it will maintain the pressure you set. It doesn't matter if it leaks out the exhaust. The system will be pressurized to want you set and then spray any connections with soapy water. You will find any leaks that you may have. Simple and easy.
Sent from my XT1080 using Tapatalk
Yes, I know how to leak test things, thanks. The point being, might as well pressurize the exhaust. It can leak too :thumb:
