leak test time :(
DieselmafiaLLY
Keep Calm and Go Crazy
Apr 6, 2013
1,102
Ontario, Canada
Had some time to work on the truck tonight so started off by doing a boost test. Your gonna laugh but I did the same thing as brian...went to open the regurator on the compressor and the pressure shot up to prob 40ish before I could run back and turn it down!:eek: anyways got it all back together and kept it at 15psi found out I had a leak at the egr, not suprised.
So my question now is what's the best option for flow? I just wanna but stuff for this once and not buy stuff then have to sell for better, my plan is all season 3" bridge to get rid of the egr with more flow and 3" boot tubes while I'm at it. But would like to hear what you guys have to say and your experiences on this eventually I want to build this motor so want stuff that will support some high hp #'s. Please feel free to tell me what you think is the best, I included some pics so people can do the same or for refrence.
Polaris7x
Dec 25, 2011
406
loves park, ill
I ran pro fabs 3 inch bridge and egr delete kit. In my opinion it worked great, it did ride pretty snug to the alternator but was good. Ive seen all seasons kits and to me there pricey but for what your getting i guess you cant go wrong. Ive seen these where they ride pretty high up, even rubbing on the hood so i guess it all comes down to who you want to go with in the end. Both great products
S Phinney
4,008
Quncy, Fl
Get up with Joe at Huron Speed. He does excellent work. I just installed a EGR delete kit on a LBZ and it is probably the cleanest kit you can by. His kit will have a uppipe to exchange with yours and gets rid of the plate. Fitment was better than the one that I did from Profab. For what you get his is also probably the best for the dollar as well. If you plan to go with a aftermarket charger don't bother changing it until then so you don't waste your money.
DieselmafiaLLY
Apr 6, 2013
1,102
Ontario, Canada
The 4094 that I have now is what I'm keeping to build around, does his kit have a full bridge? I looked on his site and didn't have any pics...I do live close to him so I could prob just drive there and get it
S Phinney
4,008
Quncy, Fl
Joe has what ever you would like. His delete kit will be piping, water hose, clamps, braces for the pipe connection at the factory bridge and uppipe. You can not move the pipe with the braces and clamps in place. The elbow will not blow out with his kit. He will do a bridge if you would like with all intercooler piping. Joe is as good as they come at fabrication and customer service. Custom work is turned around really quickly compared to most.
DieselmafiaLLY
Apr 6, 2013
1,102
Ontario, Canada
Like I said I would like to go to a full bridge as I want to buildup around it not have to buy one later, I had a nrand new profab egr delete pipe I sold bc I want to do everything now
DieselmafiaLLY
Apr 6, 2013
1,102
Ontario, Canada
well if you don't cap off and isolate the intercooler system, wouldn't it leak out form the exhaust/intake valves...? :confused:
Negative, there is no over lap on the cam....maybe you are thinking of a big cam on a gasser but when its off all the valves are closed. So I wanted to leak test the entire system not just the ic
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Last time I leak tested my system and told people that I did it like this, they told me I was crazy and that it doesn't work. I argued the crap out of it and no one believed me. Hilarious.
DieselmafiaLLY
Apr 6, 2013
1,102
Ontario, Canada
So I'm gonna look into hsp's bridge and prob some 3" boost tubes, still open to suggestions, also if someone is selling a high flow LLY bridge please pm me
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,541
526
Central OH
It will bleed through to the exhaust system. $100 says if you cap the exhaust off and put a gauge on, it will build pressure. How else do you suppose one can leak test the whole system. Every cam I've dealt with has overlap to some extent.
I'm not saying what you did won't work, but you're losing air.
S Phinney
4,008
Quncy, Fl
You only need to use regulated air supply and it will maintain the pressure you set. It doesn't matter if it leaks out the exhaust. The system will be pressurized to want you set and then spray any connections with soapy water. You will find any leaks that you may have. Simple and easy.
Sent from my XT1080 using Tapatalk
