Anyone running a stiff half leaf top of the spring pack from center of axle to front eye for anti wrap???
I went to a local spring shop for u-bolts to swap out some 4" blocks for 2" in order to level the truck out after dropping the front end down and setting it up for drag racing. I am having trouble with rear wheel hop, plan was to get the stance the way I wanted then measure for Caltracs. The guy at the spring shop may have sold me on re-arching my springs for the two inches of lift and ditching the blocks all together then adding the anti wrap leaf...
I know not having the block would help a lot and the half leaf on top isn't supposed to affect ride quality it also works from the top similar to how they Caltracs work from the bottom.
It also appears that if not enough that it would only increase the effectiveness of Caltracs if I wanted to add them later...
Anyway anybody using an anti wrap leaf and if so how do you like it???
