Does this mean there is no difference??
GM 94013303 LLY LBZ LMM Duramax Fuel Injector O-Ring Seal 2004.5-2011
dirtyhookerdiesel.com
Shop Set Of 8 Fuel Injector Connector For 04.5-10 LLY LBZ LMM Duramax at the best price. Quantity Based Discounts Available. Buy now.
prosourcediesel.com
Sent from my SM-N986U1 using Tapatalk
Swap your harness, injectors, and turbo onto the LMM motor.
If you did studs in your engine it may not be a bad idea to bite the bullet and do a quick head gasket job while that LMM engine is on the ground. It's more money but then you're done once and for all. You also can stud it one-by-one meaning remove one OEM head bolt and replace it with your head stud, torque it, repeat until all of them are replaced. When doing this I like to take them to 100ft-lbs then follow ARP's torque sequence for the last pull to 125ft-lbs.
As for the injector plugs, many aftermarket companies make parts that fit multiple years. Think of it this way, do you want to stock 3 injector plug SKUs to cover 04.5-10 or just 1? That's why they do it. It drives manufacturing price down and profits up.
