Ya like what does the OBD2 port have to do with the freakin doors, like seriously, whoever invented this electrical system in GM's was on crack lol:roflmao:
Actually its not a stupid setup/system at all........ It makes for a much more efficient electrical system, cuts down on the amount of wiring needed, reduces potential failure/trouble spots, and when you do have a problem, it makes it 10x easier to diagnose.....IF you have the proper tools such as a Tech 2, which is essential....and maybe why some people think its "stupid".
everything electrical in the truck is interconnected/networked on a common data bus. (like a computer network, the windows talk to the radio, HVAC, door modules, etc etc etc)
I cant remember the exact number of individual modules that all communicate with eachother on the databus in 03+ GM trucks/SUV's, but its somewhere around 15-20.
Think about it. If you had an electrical short or electrical problem with a "old style" non-integrated vehicle, where the hell do you start? You get out your multimeter and you spend HOURS tracing hundreds of wires, decoding schematics, blowing fuses, dealing with test lights, probing connectors, ripping apart harnesses only to have to re-wrap them with tape later, etc etc etc.
What do you do when you have an electrical problem in a 2003+ GM truck/SUV?? Plug in the Tech 2, check for codes in the affected module/zone, and then see what live data that module is reading out. That takes like 2 minutes tops. It literally makes it idiot proof and can narrow down the amount of wires that you have to manually trace down to 1 or 2.
the whole vehicle can be more efficient as a whole also. Because there really arent any more "key-on/ignition hot" power wires used anymore, (all of the modules just get constant battery + power, and then are told to 'wake up' and 'go to sleep' with a data message), that literally cuts out half the required +12volt wiring right there. And when individual modules arent needed, they can be discretely powered down without effecting any other modules in the truck...which takes load off the alternator and ultimately saves fuel.
Another example is the doors. You might have power windows, mirrors, locks, courtesy lights, heated seat controls, turn signals in the mirrors, power fold mirrors...........ok thats a lot of stuff to control. With just basic electrical power/ground circuits like older vehicles...that could easily be 30+ wires that all have to go from the body of the truck into the doors.
With a computer-networked electrical architecture, you literally need JUST THREE WIRES going from the body to the door to do all that above-mentioned crap. Power wire, ground wire, and data wire (which is the wire that carries the computer messages to/from the door to activate the mirrors, window, etc).
Three wires!!!!
Ill take the "complicated" networked/computer-driven electrical system any day.
ben
