I mounted my S464 today to see how things line up and on the downpipe side, it's not too bad. On the inlet from the air filter, that is a different story. Because the inlet to the Y-bridge on the LBZ is in the front and not the top like the LB7, it doesn't leave much room to work with. I have it sitting on a T-4 HTTurbo pedestal and this turbo only has 3" between the end of the 5" compressor housing inlet and the inlet pipe for the y-bridge.
Lifting it won't help much.
About the only options I saw are to turn the turbo, change to an LB7 y-bridge, or custom make an intake piece similar in design to the stock LBZ mouthpiece. I chose option 3 and after about 2 hrs came up with the rough fab'd piece below.
If it fits I will weld it out tomorrow, install it and pray I have enough airflow to spool the turbo!
Shut your mouth Simon.........
