Lbz pump on lb7
greendury
Jan 28, 2011
130
My 120% over lbz pump will be here Monday and I will need to rescale it. I know what table it is but not sure what needs changed?
rfletes79
649
174
Galt, Ca 95632
B1010 table. Copy the lly b1010 table and paste into your lb7 table and it should work. I know this works for a stock pump, not sure if it's any different for a 120% over. Hopefully this helps.
greendury
Jan 28, 2011
130
Would have never thought to use an lly table for an lbz pump but I sure will give it a try. Thanks for the help
greendury
Jan 28, 2011
130
Who's pump? Stock regulator or modified?
Its an II pump. I believe they modify the regulator. I'm currently running an lb7 pump with an II bag o parts. I never made any tuning changes for that moded regulator. But the regulator was for an lb7.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,496
480
Central OH
I attached the picture from Fleece's website. This is the table they have posted to use with their pump/regs so maybe it'll work. There's also a write up on Fish tuning. But those are for lbz regulators, you might be able to put your modded lb7 reg in and not change anything.
rfletes79
649
174
Galt, Ca 95632
Yep, have done several that way. Works good. You'll also have to bump up your pressures to get it up to 25k. If everything works right and you get the psi up that high you'll prob throw a high psi code and limp your truck. P0088, disable it and you'll be fine :)
greendury
Jan 28, 2011
130
I appreciate all the info I should have the truck running again in a few days to give it a try.
