Bought a 2006 LBZ duramax. I replaced injectors and cp3. White smoke at idle but I believe it had bad fuel so tank drained and fresh fuel. Still white smoking slightly so took it out on a drive. As I was accelerating it abruptly lost all power and all the right side gauges went to zero. Truck would only go about 5 mph but I was only a couple of hundred feet to get back to the shop. Truck now runs very bad and is throwing P0652 & P0522. Hooked up to tech 2 and now most of all the values on ecm sensors are reading erratic or not possible numbers or not reading at all like balance rates. Any ideas
