so to change the rods and pistons, and nothing else, the block HAS to go to the machine shop? Exactly how necessary is that? Thinking along the lines of running this engine one year, then tearing down to build appropriately the following winter.
Basically want to take pistons and rods out and put used cut lb7s with fresh rings and new rods and go. If I have the rods and pistons balanced, do they have to balanced with the crank?
I want to know what trent did to get his done for less than $5k! :thumb:
In a nut shell , keyed the crank and cam myself , cut the pistons myself , bought Howards rods and new bearings , re-used piston rings , bought head studs , re-installed everything into the motor with the minimum gaskets / seals needed , and no i didn't balance my motor but did make all the piston / rod assembly's weigh the same . I have no clue how it will hold up but so far so good
