LBZ P0087 Low Rail Pressure
AZBio
Sep 12, 2010
29
Chandler, AZ
Please Help! Truck loses power and throws the Low Rail Pressure Code around 2000 rpm's. Truck runs great under 2000 rpm's. I gain fuel pressure all the way up to 12k psi, but as the rpm's get higher and the commanded pressure increases the fuel pressure drops drammatically to 7k when commanded is asking for 30k+ psi. Any ideas?
Thanks!
AZBio
Sep 12, 2010
29
Chandler, AZ
Forgot to mention, the check engine light usually turns on in third gear. It isn't 2k rpm limp either as I can still get the rpm's over 2k, the truck just doesn't seam to react.
13,639
679
Your truck should never command 30k+ PSI. The stock sensor is only good to just over 29k PSI. Stock rail pressure is a max of right at 26k PSI.
You should try to get a gauge on it to make sure the Air Dog is putting out pressure. If it isn't running, it can cause a restriction, but it shouldn't be enough to cause that serious of a rail pressure drop unless you are really getting on it. How many miles are on the truck?
AZBio
Sep 12, 2010
29
Chandler, AZ
This is my brothers truck, but it has all the same equipment on it as my signature. It has 114K miles on it. We have checked the airdog and it is definatly moving fuel.
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
grab ahold of your fuel lines into and out of the filter.
then do the same on the flexible lines from the tank to the filter.
my lines were soft and cracked, into and out of the filter, allowing them to pinch closed
edit, oh now i see air dog...
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Still sounds like its starving for fuel, you should really put a gauge on the airdog... Did you actually test that it was moving fuel, or just hear it running? I've had pumps die before but the motor still worked.
AZBio
Sep 12, 2010
29
Chandler, AZ
We had the same thing hapen last year. Pump on the airdog was running but not moving fuel. If I hit the schrader valve next to the alternator while the airdog is running, it sprays fuel over the core support.
AZBio
Sep 12, 2010
29
Chandler, AZ
Does an injection pump slowly wear out? Or is it one of those "it either works or it doesn't"? I have checked for leaks in the fuel lines, to which I couldn't find any. I am leaning more toward the FPRV or Injection Pump. The truck also has a slight knock and has trouble starting when hot. Starts great in the mornings, but after driving it it sometimes takes cranking it for a minute or two to start.
