lbz motor build questions
Dbucholtz55
May 10, 2014
alright i just put a s366 s480 twin kit on my truck and am told that i need a built motor asap which i figured but my questions are what rod,piston and other parts are going to be needed. i am at a complete loss here. need help!!!
Huffy67
Dec 26, 2014
270
Arkansas
The only reason you "need" a built motor is if you tune it big enough to tear up the stock motor... You can tune it to run around 600 hp and be fine on the stock one and have a good running, fun truck.
Dbucholtz55
May 10, 2014
from my understanding that turbo set up will be around 700 on the small end but like i said I'm at a loss
Huffy67
Dec 26, 2014
270
Arkansas
It's all in the tuning. If you want a built motor I would use carillo rods, fingers oval bowl pistons, altered firing order cam, stud girdle, 10mm stroker pump, 100 over injectors, etc.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Sure...
If you also added those Exergy 60 over injectors and 10mm CP3 that are in your sig at the same time as the twin kit and didn't change the tune at all...
:rolleyes:
That set up is pretty much a towing twin kit, it's slightly bigger than a true towing twin set up but not an all out race kit. It'll make a ton of power if you want it to but it can also be tuned to make stock power output
I'd suggest contacting a few tuners or your preferred tuner and hashing out what you're looking to accomplish and get a proper tune "ASAP" that's what you need, not a built engine...yet
Good luck
Cheers
POWER Freak
Nov 20, 2008
46
Idaho
I say if you have the money go for it! What's the fun in having an 800hp setup tuned to 600hp? I think the post below is a great starting point for a very tough DD motor. Obviously there is a lot more a guy could do but that would keep you from the failures you're being warned about.
56taskforce
1,081
56
I think it comes down to: DO YOU NEED BUILT MOTOR NO, DO YOU WANT A BIULT MOTOR HELL YAHHHH:roflmao:
