are there any companies that make air bags for lowered truck with goosenecks? or anyone done this before? i don't want full air suspension.
The bag will have to be mounted outside the frame rail instead of under it. Kits for a 1500 that mounts on the outside of the frame is all you will find that is bolt on but won't be the same as what is offered for a 2500
Problem is the gooseneck setup is in the way
Mine mount off the rear of the axle. Still requires welding and drilling but clears the bed hitch and my 5in exhaust. Think I have some extra brackets if you're intrested
There is a company called Timbren that makes a HD rubber bump stop for towing, I talked to them on the phone awhile back and they told me they didn't make a kit for lowered trucks but I could pull measurements and they could make something work. If you don't have to have airbags it's another option.
