i can remove the intake heater out of the intake bridge on my brothers lbz with no problems correct??should flow better also right??
Didnt MMLMM make an IAH delete plate for the LBZs? Or was it SIKDMAX? I forget....
lly don't have intake heaterThats because you have an LLY, not an LBZ like your brother's truck, which is what all the following responses were based on.
No no no listen I have a lly and a lb7 one of my brothers has a lmm and the other a lbz now I am talkin about the intake sensor in the bridge between the two intake runners. It is a lbz trust me. While installing his new turbo the harness fell apart from heat exposure and I need to know if I can eliminate it or is it needed. The dealer said it is a intake temp. Sensor
yes i definately need one then. they are 63 dollars new how much do u want and how fast can u get it to me . i need it by wednesday i would greatly appreciate it . were r u located??
