LBZ: LBZ injector issues!!!
evan.goodlett
Apr 30, 2016
22
32
Unhooked p0087 stays gone. I can actually drive the truck with 7 Unhooked and it doesn't even smoke, if the injector were hung open wouldn't it at least haze because it would be leaking fuel right?
Sent from my SAMSUNG-SM-G935A using Tapatalk
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Yeah id think so. Like its responding fine. I would doubt it but what your saying is like its being told to fire left and right! I'd swap locations and see if it follows injectors or cylinder still
evan.goodlett
Apr 30, 2016
22
32
I was told today that when replacing lbz injector the balance flow rates need to be programmed to the ecm. Would not programming these balance rates cause a problem like I'm having or be the cause of my rates being out of speck?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Could be cause of balances high that's about it I would think. They need the numbers off the injector to program the Nima codes. I don't think many ppl ever do that though
evan.goodlett
Apr 30, 2016
22
32
That's what I was thinking also, I did some digging on my wiring and found that either the coolant tank sensor or the air conditioner sensor on the fire wall was cut and spliced back with a connector that isn't the right size. So I'm gonna do some more digging in the wiring of this thing and hopefully run into my culprit of why number 7 won't shut off when plugged in.
