Lbz Gt40 Intake ????
slowlmm
Mar 2, 2008
2,582
46
so cal
I Will Take All The Help I Can Get If The Vvt Sol Is Plugged In Truck Runs Great If You Unplug It It Won't Rev Over 2k Rpm. Was Setting A P2564 And A P0045, I Changed The Parameters For The P0045 And It Is Gone But The Other I Could Not Find Parameters For?
p2564 is causing your limp mode try theese changes
1. tc vane sensor
0.000000
655.000000
5.097756
655.000000
2. boost sensor
0.000000
655.000000
5.097756
655.000000
655.000000
655.000000
make those changes and you should be good to go let me know if it dosent work
redws6rocket
406
Odessa, MO
1. tc vane sensor
0.000000
655.000000
5.097756
655.000000
2. boost sensor
0.000000
655.000000
5.097756
655.000000
655.000000
655.000000
alright just got some time to mess with it i set everything like you said and i have a p0045 set and truck only revs to 2k. if i plug in the vvt sol it is just fine and no codes.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
P0045 codes
I must be missing something myself! I have tryed to fix this same thing on mine and it's not working. What is it that I must be missing? Thanks Jeff
ripmf666
15,123
14
47
Wentzville Mo
I had to grind off the 3 tabs on the LBZ mouth piece and take off some of th eedge all the way around were the clamp goes to get it to fit.The inlet seemed smaller on the 4094 turbo then the VVT.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Problems
Sorry Henry, I was talking about the codes and going into limp mode. I need to check my version of EFI and see if i'm missing some tables. As son as I start it it goes it limp. The new turbo has a 5" inlet that I need to make and a 4" discharge. I already made a 3" pipe from the turbo to the intercooler. I just want this thing done. Thanks Jeff
