Thanks for that info... Its prob stupid to think I could just hook it up and it would work.. But were all stock LBZ fuel rates the same, could the values already be the same? Did not ask if this was from a stock tune or if it had a tune on it, but? If it won't hurt anything, its worth a try. And, if you can copy/paste the values from the ECM, having the GPCM pre-installed before putting it in for programing at the shop would be ok also.. Maybe it kills the U0106 code, that would be a good sign.. I know fuel rate codes would no doubt throw it into limp mode, but it would confirm the U0106.... Any thoughtsIt will set a code for mismatched injectors flow codes
