so my 1,4,6,7 group all have a -4 balance rate... is that odd, or maybe just a coincidence?From what I have read, the ones with the -4 balance rate are in the same injector group. They are grouped so the front and back cylinder on one side are grouped with the two middle cylinders on the other side. So 1,4,6,7 would be in one group and 2,3,5,8 would be in another group.
edit: I know that is true for the LB7 and LLY. I'm just not sure about the LBZ.
The LLY i worked on, when I turned off #6 with EFILive DVT's it would quit smoking and knocking.
I raplaced injector #6 and still the same, I read some prior testimonials after that... I borrowed a Tech 2 and when I shut off injector #4 it stopped knocking and smoking, so I replaced injector #4 and all is better.
All of the balance rates were out of spec while this was going on, but #4 cylinder was the only one that always stayed a -#, mainly stayed at -7 or around there... So I thought it might be the one once I replaced #6 and it didn't fix it...
Others thought with the DVT that #6 would be #6 in the firing order, but that doesn't work out either... #4 cylinder is 5th in the firing order...
Anyone else have any speculations or proof of which # in DVT is which cylinder for the others???
