LB7: LBZ Fpr?
ZeroGravity58
1,401
51
Maryland
i picked up about 2K extra of rail pressure when i did mine with the same tuning. You need to adjust the B1010 table to get it to idle right.
SparkZ03DMAX
Nov 16, 2009
866
North Carolina
Does idle change a bit when it's installed? I've changed my FPR before, but I just replaced it with the LB7 one. My truck is starting to idle "lopey" again and I kind of figured I would get the LBZ one to smooth it out but it could also be because it's getting cold down here in NC
Operator1
477
NC
Raising the idle rpm a little can help to smooth it out. IIRC, the early duramaxes had a lower idle and LP pressure affects them more. If it was my little list, an arson kit would be a better addition IMO.
mispeeld with tapatalkz
ZeroGravity58
1,401
51
Maryland
You will have to adjust b1010 to get the idle right. When I first started mine up it was idling at 18k on the rail. You have to adjust the first three blocks to get the idle where you want then blend the rest. That's what I did and it worked great for me. You could try changing the idle rpm also. I think the early trucks idled at 600 rpms and the later ones were 680 rpms.
