my blow of valve is plugged and i couldnt hit 26k for the life of me. I have a modded lbz in it now and have no trouble at all.Correct, and I think he asked the follow up question with the 26k rail pressure, could be wrong tho.
I bet you can hit 26k with the lb7 regulator, I havent tried it yet tho. And some people have had the rail pressure safety valve, like a rail pressure blow off valve, open at 24500, some 25000+, we dont have to "shim" our valves so they hold rail pressure
I held 190 mpa with a 3250pw tune with the lbz regulator but now with the nozzles can't even hold a 2200 pw above 20ksi so need a bigger pump now
Mine on stock nozzles held a 3250 pw?? But like I said with nozzles dropped way down even at a 2200 pw
Does you turbo even clean up what you have now?
