LBZ ECM Issue
Bonestock
1,358
Worland Wy
I have a buddy who messed up and fried his ecm. He was just trying to change out his batteries in his stock ppe tuned lbz 2007. He had a dumbass attack and unhooked the positive lead first and it shorted out against the case of the ecm and you know the rest. Anyhow he bought a new ecm from the dealer and another friend installed it for him. Then they called me to flash a stock file in the ecm. I had a stock 07 lbz file so I flashed it in. The problem he has now is the check engine light is on and code 268 is popping up. I did some reading on this and it states that injector flow rate codes need to be programmed into the ecm. Is this only done with a tech 2 or is there some other work around? Has this happened to any of you before?
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Wow never heard of the flow rates needing to be in. When a bullydog unit cooked an lb7 all we did was get a new a ecm from the dealer and flashed in the correct os tune.
Lbz is quite a bit smarter though maybe it needs more info?
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Lb7 and lly don't need flow rates programmed. Lbz and new do sometimes. I'm guessing with a new ecm, it will in fact need them flashed in.
13,736
806
You can use your V2 to copy them from the GPCM to the ECM.
