I'm getting two messages on the dash, one is "water in fuel", and the other is "low coolant level". I've tried replacing the fuel filter and draining the water separator on the airdog, and neither has fixed it. The coolant level in the truck seems fine, and it holds consistent temp at ~185. The other day on the way to work it stopped blowing hot air and the temp skyrocketed until it pegged the gauge, but it instantly dropped back down to operating temperature and started blowing hot air again. Could the issue be a sticky thermostat?
