LB7 who offers best Head Gaskets in a kit??
kubitza123
Sep 19, 2016
144
Texas
Well mine rig now needs head gaskets , guess I need to buy a Toyota so I got something I can drive while I work on my Duramax all the time.
Who makes the best head gaskets? If I can get them in a set with Arp studs great let me know where . If not I'll buy separate .
tsd_billy
457
oklahoma city
Alliant power , i use them in all my 6.0 stud jobs and they sell a stud kit right around 899 so its not a bad price and they have a warranty, they leak no problem no questions, just new gaskets
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Put gmLml gaskets on it with studs or new bolts. Depending on power level and goals bolts are fine.
Many dealers cab set you up.
kubitza123
Sep 19, 2016
144
Texas
I have my own lift at home, easier to pull the cab or engine to work on???
I have a bad back and no way I'm fighting it leaning under the hood to do it.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Lift the cab. Removing the engine is way more work in my opinion.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
If you can't find a package pm me and I'll set you up with someone
Brent@LDS
651
Wisconsin
We can help you out here with Grade C LML gaskets, and ARP studs. In stock ready to ship! Let me know if I can help.
bmc1025
521
Big Bone, KY
Cheapest way I have found is order lml gaskets from Rock auto or amazon and get 2 mahle/Victor rienz bolt kits and a HG install gasket kit from Victor/Mahle also. That will give you all gaskets and silicone you will need. There may be some fasteners like the fuel return rail bolts you may need to replace.
Total price of about 350 give or take.
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
^X2 have to agree. I haven’t been around very long but lds is very competitive with this. Or like bac said piece it togather yourself and hope it works. Glw doing the gaskets.
kubitza123
Sep 19, 2016
144
Texas
I got my last injector from Brent and great to deal with so he earned my business, just forgot they offered other parts since most post involve injectors .
Brent@LDS
651
Wisconsin
As of today we arn't just doing injectors, but everything from bolts to turbos here. We are a one stop shop for all your duramax needs!
aashton1206
172
Rent also give great support if you have questions on the whole install
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, PPE Race Valve, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Platinum AGM Duralast, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
