LB7 Voltage Dip
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Not aftermarket, no. OEM replacement from O'reillys.
I'll check the output cable also.
OReillys= aftermarket made in mexico. Unless it's a genuine GM or AC DELCO, you got aftermarket. Put an ampmeter on the alternator output wire and see just what it is producing at idle. Like I said earlier, beings you got an aftermarket, there is also a chance you got a CS-130 D instead of an AD230. Most people do not know how to tell the difference as they are rather subtle. Theres nothing really wrong with a CS-130D, but they don't seem to put out as much at idle as the newer AD series does.
OnixMax
66
Noted. I'll take a look tomorrow when I check the ground too.
jlawles2
1,062
40
Danbury, TX
You might also want to have the batteries checked. Even though they are 2013, I have seen them go bad in under 12 months. Bad batteries cause strange things to happen.
OnixMax
66
The more I think about it; the more I see some weak battery symptoms... (Could be all in my head of course). Lights dim when I put the windows up. Cold starts during the warmup process, voltage is below the 1/4 mark (above 9, below the mark below 14). I'll have the batteries tested, just to possibly rule them out
