Need some help guys. Buddies 02 LB7. Has a built trans, dual fuelers (tune runs stock pressures max around 23k), AD165, HTT 66. Truck spun the harmonic then other day and we fixed it with EDPs pin kit. Took the truck for a spin yesterday. It was running perfect, right before we got home we hit it from a slow roll and the truck spun a ways. Came to a stop and now the truck is making a muffled exhaust leak sound. I couldn't narrow it down last night so going again tonight to look again. Idles perfect, oil pressure warmed up at idle is about 20 psi, the noise does increase with RPMs. Its overall not extremely loud. It isn't like a knocking noise. I stuck my had by the turbo gasket and up pipes and didn't feel any exhaust leak. Balance rates all looked good as well. No codes either. I did some reading and a guy described a sound similar and it was his copper washers on injectors. Could that be possible? Truck has 145k but injectors were done about 25k ago. Oil looks clean on the stick, no fuel from what I could see. Just looking for some ideas to get this narrowed down. Thanks
