The reason I mentioned it was because I read where someone recently posted that the main issue causing the LB7 injectors to fail could be heat (constantly soaked with hot oil under the valve cover and higher voltage) and so I was curious if the higher voltage might create more heat in the lly injectors and also make them fail at a higher rate.
According to my ties in the diesel injection business, the lly isn't far behind the lb7 in number of failed sets.... they're higher voltage than lbz and likewise, have more failures than lbz/lmm. Same story with lb7, they're higher voltage and oil soaked and just so happen to have more failures than all the others, as we all are aware of.
The good thing is, even if/when the lly injectors fail, they're sooo much easier to swap out compared to the lb7.
Just thinking out loud here.
