From what I read, there is not much to it. Please feel free to correct anything I may have wrong below, as this is what I have found so far.
On the C100 connector
Body side "C" (BN) needs moved to "N"
Body side "M" (YE) needs moved to "R"
Body side "G" (TN) needs to be moved to "J"
Add a purple wire to "B" for 6spd tap shift, tap into the pink wire on the steering column
Add a wire to "F" for GM LAN (+)- You'll run this wires to the OBD port "6"
Add a wire to "G" for GM LAN (-)- You'll run this wires to the OBD port "14"
C2(in electrical center AKA under hood fuse block):
Move the Orange wire from F4 to A8
The wire you move on C2 is the TCM power.
On the C2 harness under the fuse box, there are two orange wires that need to be moved to match where they were on the LB7. If not the truck will crank/die about 7-10 times before starting.
The lower rad. hose is diff. LB7/LBZ so I cut the two in the center, inserted a 2" SS tube bead rolled on both ends.
The LBZ Intake Heater grid fuse and fuse holder need to be added to the LB7 as well.
It was a pretty simple swap, and I would do it again over LB7 injectors in the truck anyday, lol. Some more needed PN#s below...
Petal PN#15233970
Petal harness PN#15233968
Shift indexer PN#15866124
Shifter PN#15860125
Small pins Male #15326269/19 Female #12191819/8
Large pins Male #15304731/19 Female #15304719/19
** A 6spd. trans needs to be used, or convert your 5spd. to a 6spd.(TCM, NSBU, Internal harness, Valve body) 6spd tap shifter, 6spd cluster, LBZ throttle petal and petal harness. Am I forgeting anything?
Petal PN#15233970
Shifter PN#15860125
