I'm in Michigan, my brother is in Florida. He has a 130,000mi 04 LB7.
He just had the injectors replaced at a local shop. Injectors and new lines came from LDS. The truck also has a lift pump, but that is just for injector health, I do not believe he has any tuner on it at all, tune is stock.
Now he tells me if he is running 75 to 80 mph and lets off the throttle, he gets a rattling noise. Sounds like a collapsed lifter or he even mentioned a rod knock.
The shop that did the install hears the noise as well, they test drove it with him, with a scanner hooked up, all pressures are good, scanner shows nothing.
They are telling him the fuel lines get a "harmonic" cycle going at some RPMs and cause the sound he is hearing.
Anyone have anything like this happen?
I'm thinking cracked flywheel maybe?
