Lb7 quick start?
Awenta
4,090
CT
The thud you’re hearing does sound like abs. But you should hear it in the lb7 too. It’s like a thud and wind down.
Mine kicks over plenty quick, it's just never popped off quickly. I've run multiple operating systems, bad cp3, new cp3, and several sets of injectors. So far the only time it popped off semi-quickly was with the junk pensacola injectors, in which case it chugged to life with the bump of the key, with blue smoke galore everywhere, and it ran the quietest with those injectors too. But I know it wasn't right when it was that way. Whats weird is I know it builds rail instantly because it will normally show 3k+ when it starts up, and the injectors are triggered as soon as the ecm reads cam and crank to know where its at. Yet it still takes its time to pop off. So it's just a roll of the dice.
Probably because the cylinders were already filled with fuel from those injectors leaking haha.
