I have fuel up to the cp3, I am going to run that line though since I have everything apartMaybe think about switching out your sending unit. And this is one of the main reasons why I think its dumb some people run cat filters. Water in the fuel reads havoc. Also I use 1/2 in steal braided fuel line with AN fittings I believe the brand is Vibrant super easy to make up the lines you need and very durable.
If it's the cp3 I'm going to get a sportsman, any cp3 that has been removed is instantly only worth it's weight as a core imo,you never know how the person removed it and stored it.I sure hope it isn't the pump bud if so I have a friend with a 02 and a bunch of spare stuff including stock pump if you need one I could get it for a bargain. His is all built but he saves everything. I'd just have to give him a ring and ask. Let me know.
I have seen one run with a sheared gear pump shaft. As long as there was positive supply pressure it would continue to run. Just would only build about 8k/26k psi.
Easiest way to dead head the pump on an lb7 is to take the 2 old injector lines and cut off the rail ends. Weld the tube shut so you now have a block off plug. Disconnect both rail feed lines from the fprv/rail pressure sensor block on the drivers side intake clam and install your block off plugs. Now you have effectivly dead headed the pump into the rail sensor. Crank the engine over and see if you have rail pressure. If you do then you have a fubard injector. Hook up one side at a time to isolate it to driver or pass. If you still have no rail pressure then check the fprv. It could be pinned open from a piece of trash or something or broken spring. Disconnect the big return banjo from that block. If you have any fuel come out of the fprv it's bad. If nothing leaks from it, you have fuel going into the cp3, and no rail pressure when dead headed it's got to be a dead cp3.
Dang that is alot of testing, I'll do what I can. In the end I'm pretty sure it's the cp3 it's been weak for a while and it's surged several times on the freeway and has a bad lope at idle, either way I need one I guess haha
