Hello. I have an issue with my lb7. What i have is an 01 gmc sierra 2500. Heres the history. Few months ago i pulled the engine and installed front and rear seal, head gaskets, injectors and sealed everything up and set valves. Did it by the number. Eveything has been fine until today. 20 psi at idle and 30 at hwy speed warm. Normally 30 or more idle and 50 or more hwy.
I have about 5k on rotella 15w40. In the 5k miles ive added NONE and today it was less than a quart low. 333000 miles on bottom end and now 10k on injectors. I have no diesel in my oil that i can tell. No leaks anywhere of any kind on motor.
The gauge on the dash has always acted funny. Kinda jumpy. But worked.
Any ideas? A possible sender failure? Gauge failure?
The engine makes no noises. The truck cranks fine, runs fine, has no fuel smell or smoke associated with injector failure.
