Hello there
Im having some issues and not finding much on this issue to solve my problem. Was towing a car trailer a week ago and as i came to a stop light the low oil pressure indicator light came on and it had a slight knock and noticed my electrical oil gauge was bouncing up and down.Took it home and parked it well since then i have installed a mechanical gauge into the oil filter housing did an oil change also i run Lucas oil stabilizer and 15 40 oil. On initial startup i have good oil pressure,mechanical one says 90 my stock one says 60. Go and drive it around for a little bit till it gets to running temp and then come to a stop light and sit there for a minute and my oil pressure drops to about 6 psi for a split second then jumps back up to 10 or so. I just did head gaskets at the beginning of this year has had no issues for 8 months. Is there anyone that knows how to trouble shoot to see of its the oil pump? or should i just pull the motor and replace everything i can involving oil?
