LB7 LLY Water pump fix-is there a solution?
RickDLance
1,276
14
I expect you'll find being properly balanced plays a bigger part then most would think.;) The water pump and the engine.
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
Are the LB7/LLY water pumps that are letting go genuine GM or are they aftermarket pumps as well? I know I have had problems with aftermarket(autozone and advance) water pumps in other applications here lately. I put a genuine AC DELCO from GM in my BURB, but then again I'm only running around 400HP to the wheels on mine(can't afford to play in the big boy HP league).
I'm with THEFIRM here, I installed an LBZ on my LLY simply because of failure frequency whether stock or built the LBZ's last longer, plus the pumps better capacity and lighter impeller are a plus. my .02
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
904
31
Western MA
www.matpa.org
I understand how a rotating assembly is balanced, but how do you balance the water pump?
If it's zero balanced at the factory, adding weld, pinning, keywaying, etc must all throw it off balance...
wrcknkrw
447
roy ut
Will the LBZ bolt right in place of a LLY pump without modification? I need to change my pump currently.
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Well we tried about all the fixes available up until the end of last year and went to an electric pump. End of problem. Another nice thing is you can keep the pump on and circulate the water when you are between passes on the strip and help cool it much quicker.:thumb:
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
Just had to modify one of the top mount hole locations on the pump (cut and drill only) and heat and lube up the LLY radiator hose to install on the larger inlet and that was it. So far so good!
Electric is the go for race only applications for sure.
xcablb7
Feb 8, 2009
536
Fall River
my stock pump lasted a month at 710 hp, the chance of it failing away from home, and not being an easy side of the road swap led me to go straight for the electric. year and a half later still going strong with no issues. i was all set with trial and error that i've already seen dustin and a few others go through
Kennedy Diesel
Mar 13, 2009
66
So you are saying you lunched the OE LBZ pump?
It wont bolt direct but if you would like i could get you fixed up.
The "customized" pump that Tony did for me is on and held up all day with my thrashing.
In the 11th hr I made a major breakthrough with my tuning so wil luck I won't cross 4,000rpm much if at all.
Things are finally starting to come together...
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
Thats great, cant wait for the results!
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
Love my electric pump....wouldn't trade it for anything. I did drill my tstats and I run a 30psi cap now too. I run my truck without any fans on most of the time now, and it has stayed below 210 water temp and oil temps go to 220 only on wot runs
maine04max
Dec 11, 2008
1,009
Im not sure if your saying going electric is only for racing , but I have electric on my truck and have driven it everyday for the last 5 months with out one issue .
