Lb7 leaking coolant
CaptPhil
1,012
Delaware
Did you pull the thermostat housing or hard pipe? I pinched the o ring putting mine back on once and it leaked coolant.
Lb7joezay
Just checked out my hard pipe but there's no leak around it but I did pull the thermostat housing off but I don't see any external leaks around that area unless its internal
Lb7joezay
It came out to be the thermostat housing gaskets both sides were worn out pretty bad but I got it taken care of and now it's running pretty good with no leaks.
thanks
