lb7 injectors
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
An auto cal can handle that. It's only limitation is, you can't write your on tunes
Casey
Sep 12, 2014
40
but i would still have to pay $600-700 for autocal then whatever it is for the tune so on so forth my budget ant much after doing headgaskets cp3 injectors and a bit more.
dordtrecht5
Regular Cabs Rock
Jul 21, 2009
900
Wherever I am working
Your tuner can do this for you. He can mod the ecm to accept the lbz regulator. You're thinking to hard about the process.
Head gaskets...check
45% SAC...check
Having Tony Tune your ecm...check
Everything that you would need to do with a V2 to your ecm Tony can do with his V2 to your ecm.
You CAN run a stock tune with 45% injectors. What we are saying is that IF YOU TOW the 45s will be hot and you will really have to watch egt.
When you have enough money...get your truck tuned. If you the money to get an ecm tuned by mail Tony can do that. Do that while your doing you HG and injectors.
If you can get an autocal, financially, do that instead of the tuned ecm. The reason why you want an autocal is because if you want Tony to make adjustments tot the tuning you can send him files of your truck running and he can tell where the changes need to take place.
Casey
Sep 12, 2014
40
45% SAC...check
so i could just tell him i have the sac 45s and a lbz cp3 and he can put that on my tuner when i order if i go with the autocal or ecm and will say LDS take my lb7 core for a lbz cp3 or do i need to buy a junk lbz cp3
Casey
Sep 12, 2014
40
if i was to buy a autocal from you guys as well could you tune it for the lbz cp3 and the sac injectors as well? before shipping it or is that something that has to be done after i get the autocal. i will be ordering everything from you guys the middle of January i hope to have my truck apart before then so i can send my cores before hand to wave the core charges. do i need to contact you guys before ordering the lbz cp3 because of the lb7 core for that or do i just send it? thank you in advance
Casey
Sep 12, 2014
40
ok so parts list is now and going to stay unless anyone thinks i should change anything..
* grade c headgaskets
*arp headstuds do i need these some people say yes some say no?
*lbz cp3
*SAC 45% injectors
*fuel filter rebuild kit with new screw
*autocal tuned for the lbz cp3 and 45% injectors
*Wehrli Custom Fab 3.5" Turbo Horn worth it?
*Edge EAS STARTER KIT W/ EGT CABLE FOR CS/CS2 & CTS/CTS2 (expandable)
*new filters for my fass lift pump
anything else i should add i already have a fel pro gasket kit. will buy injector lines if mine wont come clean. have to save money for the heads to be checked don't know how much that usually is.
Casey
Sep 12, 2014
40
was going to do exhaust, down pipe and cold air intake but those will have to wait mabye we will see if the budget allows i will be doing 4" exhaust 3" down pipe and a s&b cold air intake. also going to do all new rubber fuel hoses. want to say thank you to everyone for all the information iv had this truck going on 2 years and this will be my first time tearing into it for anything major. forgot to mention i already did the pump rub fix just did that 3 weeks ago.
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
I have never seen over 17k rail pressure. Pretty sure I need to do the cp3 that's with a fass 150gph lift pump. Is there a sure way to test cp3?
Didn't read the whole thread but if not mentioned yet...
When my returns on my LLY injectors were shot, I never saw over 17-18k rail pressure.
I had a lift pump set at 15 psi, had a PPE race plug and ran all new fuel lines.
I had the motor built and the injectors came back very tired, put a new set of 30 overs in and it head 23.5-24k all day on any tune. Same old cp3 with 200k miles.
Casey
Sep 12, 2014
40
mabye ill have my cp3 tested before buying a new one if its healthy i could wait on cp3 and do other things.
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
10-4, just figured I'd mention it, I was gonna replace mine and I was told it probly wasn't it, so I quit pissing with my fuel problem til I put a hole in a piston and had 3 more ready to go, that's when I sent out the injectors and found out they were junk. I could unplug my fpr and command max rail pressure with a tech 2 and still not get over 18k.
Awenta
4,090
CT
You could just buy a good used lbz pump for like 300 bucks too
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
No idea, I believe there is a DIY thread here to check fuel return rate. Basically unhook the return line and put a long hose in place of it and measure fuel return for so many seconds, lift pump will have to be off and bypassed if not a flow through style to get a correct measurement.
Casey
Sep 12, 2014
40
but how would i know that the used cp3 is good and not garbage when a new one is like $600 ill just pull it when i tear into the truck if dealership charge to much to test it ill just buy a new one with my fuel issues would rather just change everything while i can. im just trying to eliminate the problems i have ben having all at once that way i don't have to tear into it 6 months down the road hopfully.
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
If I had the top tore down that's what I would do just because I get irritated just changing my oil anymore let alone pulling a cp3.
You can find cp3's for 250-350, But if your fixing it on a tight budget the test is an option.
