LB7: LB7 injector?
Gello
129
Hi guys
2 questions I have on injectors.
I have no smoke at this point with 42k original miles on my 04 lb7. First question is: if some of my balance rates were approaching 4.0 would this have a performance issue as far as loss of power? 2nd question: what's the best replacement injectors out there now? New or rebuilt? I know it's only a matter of time! I'd appreciate any advice!!
Thanks guys!!
zakkb787
<that’s not me...
Sep 29, 2014
2,340
52
Granite Falls NC
The closer to 4 you get it'll probably start hazing on you. And the second question consensus seems to be the SAC style injectors from lincoln diesel. But the smallest size you can get are 45 overs so you'd need efi. As far as stock size you can not beat lincoln diesel as well
Gello
129
Thanks I'll give it a shot.
Brent@LDS
651
Wisconsin
If you end up needing injectors check us out for all your injector needs. We carry the best warranty in the industry and have great prices.
Gello
129
Will do Brent. I will be doing them by this fall
astrnaughtwanabe
Sep 26, 2014
Wellington, CO
i had zero performance issues, no loss in MPG, no fuel in the oil. the only symptom i had when my injectors were bad was light smoke at idle, I got my injectors, went with bosch remans from Lincoln Diesel, great people to deal with.
