lb7 injector and leak problem
duravette
Sep 6, 2011
13
so this week i just got done replacing all the injectors in a lb7 and i finished it and started it up and it ran like a charm. I let it idle for about 30 minutes and as soon at i put it in gear to test drive it, it started leaking fuel and died on me in about 100 feet. i searched up and down for where the leak is but i cant find it, its seems to be on the driver side somewhere in the back of the motor. the truck wont run it just cranks over. :mad:
ripmf666
15,123
14
47
Wentzville Mo
could be the feed lines did you make sure they were clean and tighten them down even not one end at once then the other?
duravette
Sep 6, 2011
13
yeah both ends are tight, but now that you say that it could be leaking from the return.
duravette
Sep 6, 2011
13
when i crank over on it, there is maybe a drip every couple seconds. but when i drove it and it started leaking there was a small steady line.
