LB7 shop plow truck has been at 2 different repair shops trying to figure out why its stuck in limp mode. Boss brought it back over from the last repair shop and wants us to figure it out.
Back story. Truck has had a hard life. Sits all summer and get abused in the winter plowing. New plow put on it and some underhood wiring cleaned up. Few days later. Truck goes into limp mode. Gets sent to trans shop and for a few weeks and they give up. Next shop it goes to they put a used trans in it, 4 TCM's and allegedly had a tech from GM shop look over wiring harness and try to figure out what was going on.
Gets to back to our shop and I scan it with my auto-cal:
P0380, P0405 (not too worried about those yet) P0802, C0035, C0040, C0055, U1000, U2106
Worried about all the communication codes.
So far I've cleaned all the grounds and repaired a few that were suspect. Looked over as much of the wiring harness and I could see. Pulled the underhood fuse box and checked the wiring underneath it.
Looking for a next step or problem areas where the harness may rub. Im assuming that this is a wiring or electrical issue because of the comm codes
Thanks
Thanks
