I have a lot of unanswered questions regarding the performance of my federal LB7 I plan to swap into my dodge truck. All advice is appreciated guys.
1. I want a set of 40% over nozzles or somewhere around there but don't know where to go. Option 1 is to send my nozzles to Extrude Hone and for about $300 get them enlarged. Option 2 is buying a used set of Exergy 40% overs for $800, they only have 10 hooks on them and no street miles. I know the Exergys are balanced better but how much does that really effect the engine?
2. How many issues arise with cylinder pressure blowing injector cups out or causing them to leak? I was planning on using an 80mm single and have heard that the added pressure will most likely cause issues. Is it difficult to weld or thread the cups into the head? Will billet hold downs help? I've been thinking and I'd also assume an aftermarket cam and thicker headgaskets would help to lower cylinder pressures would it not?
3. Has anyone ever used a diverter valve and a big single together? In theory it would work great but drive pressures could get a little high. Just curious.
