iirc a couple guys from ohio ported out there lb7 fuel rails....They said it threw CRAAZY fuel to the stock injectors with dual cp3's....They also had a custom gt42. Well they ended up throwing a stock rod threw the block in less then a mileOn edit i dont know the rail pressure or pulse width they were running but they said that it smoked like a Train even when the 42 was fully lit
Thanks Eric
but where does the fuel line come in on the lb7?( duel Cp3 ) I assume that it comes in where the plug is? the same as the LLY? meaning the second CP3 doesnt have a orfice anyways
I mean i would rather have crazy fuel and turn it down, than not have enough fuel
