Help: LB7 ECM trouble
ikeG
Oughta Know Better
Apr 19, 2011
2,461
146
Western PA
www.facebook.com
Got a 02 LB7 here, heres the story. Trans is slippin when converter is locked, keeps goin into limp mode. Runs really well, no dsp switch. Tried to pull ECM file, says locked. Decided to have GM reflash to stock with Tech II. They say the had trouble. Brought it back, same issues.
NOW, the thing will only crank for a while, run just for a split second, then shut off. Security light on all the time. Setting these codes: U1041, U1096, U1064, and U1000. What might be the issues? I unplugged the bale connectors, looked at those pins. seemfine.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
What's any of that have to do with the transmission slipping? Sounds like possibly there was a different then stock calibration in the ECM and that's why perhaps there was a issue at the dealer. Then it was flashed with a 02 stock calibration then the vats kicked in. How it reset who knows but it's working fine so no worries.
Now investigate the slipping transmission.
ikeG
Oughta Know Better
Apr 19, 2011
2,461
146
Western PA
www.facebook.com
Want to put stock tune in to see if trans still slips. People are not wanting to build it. They bought it with this tuning in it. Trying to reflash @ dealer opened another can of worms. Does it sound like the ECM is toast? vin stored is heiroglyphics.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
If it slips it slips so it's going to need repair . Truck runs with the dealer flash so you've said so what is the issue? What are u using to read the ECM? Looks like you have EFI
ikeG
Oughta Know Better
Apr 19, 2011
2,461
146
Western PA
www.facebook.com
It only ran for 5 mile to get home, then after shut off, only crank for a while, run just for a split second, then shut off. Security light on all the time. Setting these codes: U1041, U1096, U1064, and U1000. Pulled fuses, problem now gone. VIN in ecm is in jibberish. Is the ECM toast or what?
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Not understanding the DTC codes. I truly cannot tell you if your ECM is toast. You say problem is solved so it runs ok? I'd assume if it was toast the truck wouldn't run. If it repeats then find a used ECM and with your EFI You should be able to flash a stock 02 calibration in it. I'm sure someone has it here and would be willing to give it to you.
Good luck
3,724
292
My roadrunner ECU reads gibberish as the VIN but runs fine.
Try checking the health, and if it's OK, try a full flash. I would assume a gibberish VIN is not a good sign on a non-roadrunner ECU. You might be in the market for a replacement ECU soon, sorry.
Sent from my Galaxy Nexus using Tapatalk 2
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
I would try a full flash of both the ECM and TCM with a good tune. But I'm not really smart when it comes to working with the actual ECM so I’m just guessing here
rgullett83
1,607
Illinois
i am guessing the ecm needs replaced due to the reflash issues, the DTCs that start with U are communication dtcs ie, between different modules on the data bus. My 01 had a corrupt ECM when i bought it, had no running issues, I just couldnt read it or flash it when the time came. I bought a used ECM from Guy at socal, flashed in an 02 OS, and have not had any troubles since.
whytry
Oct 11, 2010
282
Guy at socal can help you....he will fix your ecm for cheaper then a new one.. He knows ecms...just sayin been there before with corrupt ecms
