Got a 02 LB7 here, heres the story. Trans is slippin when converter is locked, keeps goin into limp mode. Runs really well, no dsp switch. Tried to pull ECM file, says locked. Decided to have GM reflash to stock with Tech II. They say the had trouble. Brought it back, same issues.
NOW, the thing will only crank for a while, run just for a split second, then shut off. Security light on all the time. Setting these codes: U1041, U1096, U1064, and U1000. What might be the issues? I unplugged the bale connectors, looked at those pins. seemfine.
