LB7 Coolant issue.
Atouchofgrass
Jun 19, 2010
526
CT
Well for about a month now i've been having a coolant issue with my 02 reg cab lb7(The truck currently has 167k). Their are two things that pop into my mind that it could be, injector cups, or head gaskets :(. It spends most of it's time towing a trailer during the week, but some days i come home with a full coolant bottle, some days it's low and the coolant light comes on. Some mornings, the system is pressurized, with low coolant, other times it full and no pressure in the system. I literally am at a standstill. I'm gonna try and do a compression test this week, but the funny thing is it definitely not burning it, and the oil level is fine along with looking perfectly fine. It run's like a top, and no overheating at all. I just don't want to run this truck any longer with this happening especially since winter is approaching, and it will be used for plowing. Any input would be greatly appreciated! :thumb:
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Mine did the same thing and i did new gaskets and pulled all injector cups and resealed them and problem solved.Make sure you use the high temp red loctite its not the easiest to find but its good to 500 degrees instead of only 350 for regular loctite.Henry and Darryl can hook you up with studs and gaskets pretty cheap.Good time to port the heads while your in there :D
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
A good test of the cups/gaskets would be to let it sit all night, then make sure the coolant system isnt pressurized by opening the coolant resivoir cap and retighten it. Then start the truck while its stone cold and immediately power brake it in the driveway for about 20 seconds then pop the hood and open the cap and see if the coolant system is under pressure. If it is then you definitely have combustion gasses entering the coolant system.
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
kspent..... who told you that?
Nobody, its a process of logic. If the coolant is cold then there will be no "steam" pressure from the coolant getting hot and expanding. When you power brake it (and when i say power brake i dont mean put both feet flat on the floor and roast the tires, i mean give it slight throttle while pushing the brake to put a load on the engine to increase cylinder pressure) if there is a head gasket or lifted cup then the cylinder pressure will escape into the coolant system causing pressure.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Put the overflow line into a bottle and drive it. If there is coolant in there after driving the truck real hard then odds are its cups. If there is no coolant after beating on it hard and the radiator hoses are still hard then its most likely gaskets.
You can also remove all the glowplugs and pressurize the coolant system and let it sit over night. The next morning look for coolant seeping out of the holes. You can narrow down which side it is and what cyclinder. Tear that side down and remove the injector cup of the suspect cylinder. If the bottom of the cup has soot trails then I would reseal the cup and put it back together. If no soot then keep on digging until the head is off.
Atouchofgrass
Jun 19, 2010
526
CT
I'm leaning towards gaskets only because i know it isn't leaking out of the coolant overflow because their would be coolant all over the passenger fender well... It's playing mind games with me because some days it's perfectly fine and some days its down coolant. What is whacky, when i do release the pressure from the degas bottle the coolant is at a normal level. Could it even be a bad bottle cap?
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
no way its the cap IMO mine did that and i tried 3 different caps and it still did it i also kept pulling injector cups and resealing puting it back together and still having a problem Get the studs and gaskets injector o rings reseal all the injector cups put it back together and then its back to rollin coal:thumb:
Atouchofgrass
Jun 19, 2010
526
CT
I know, i just don't want to quit trying :rofl: Might as well do all eight injectors while im in there.. I did a balance rate test and two are out of spec, great :roflmao:
